AnotherS197GT
Serial Valve Dropper
Give me a shout next time you need help. I'll take a ride out and give you a hand.
Textured Black ForgeStar 19x9 and 19x11
Did you remove the grille fogs and add them in the bumper and change the griles? Car looks great so far.
JJ the new ride looks badass!
Started to swap out my mufflers once again after blowing one out a week ago. Took my last set of Bullitt mufflers out of the shed and discovered that they sound like a bag of broken glass when shaken. I bought them a year ago and never unwrapped them until now. $250 right down the drain.
And now I don't have any decent mufflers to put back on the car.
Replaced my oil filter relocation hoses, re tightened all the v bands on the turbo piping and adjusted my exhaust a little bit. I was able to get a little more clearance but im hearing a small leak somewhere. I'll save that for another day.
I also added a spring to the wastegate. With the spring that came installed in it i was seeing 4lbs. I added the blue spring and am now seeing a spike to 11psi and then it holds at 10psi.. Man what a difference 6lbs makes. I can't wait to throw another 8psi at it and see what it does in the 18psi range.
a good guess is around 18 HP per PSI....at least with a twin screw.Replaced my oil filter relocation hoses, re tightened all the v bands on the turbo piping and adjusted my exhaust a little bit. I was able to get a little more clearance but im hearing a small leak somewhere. I'll save that for another day.
Hope you are forged when you hit 18psi!
Long day for sure.
First I would like to thank Jeff, Mike and Jason for all the help today. Still have a lot of work left, but if it wasn't for them I wouldn't even have go this far. We swapped parts from my 2012 to what is now going to be my 2013. The 12 is going to the way side.
Forgot to take a pic of the BMR K-member with everything on it as well as the one piece DS. It is frick'n awesome even though it was a PITA. Really cleans up the underside and tons of room.
The supercharger still needs to be installed along with the BMR Radiator support. Like I said, lots of work left, but a great start.
Oh yeah, still have to put the black car back together.
Nice! Enjoy that power!
Fuel system built to handle 18 psi?
May need to upgrade injectors with the 18 psi but other than that you look good.
