IW balancer wont come off
05stroker
Never enough power guy!
Bullard Tx.
I have tried pry bars impact so far and it won't budge. I have the puller mounted and have hit it with a impact maybe 40 times. It seems to be seized on the crank.
Anyone have any ideas before I cut it off?
I have thought about calling Brad at IW tomorrow to see if I remove the alum. outer part if they can sell me the steel hub by its self. So I can cut the hub off.
lethe
V4g!n@ #er
Everett, Wa
It may sound stupid but did you make sure the washer wasn't still in there?
Department Of Boost
Alpha Geek
I learned this the hard way......
Billy:
Can you put a breaker bar on the flex plate end of the crank and one on the balancer tool? The problem with the impact is that it is not getting full "impacts" because the crank being able to rotate slightly absorbs the "hits".
05stroker
Bullard Tx.
Did that once before, yes it is off.
Single key or dual key? I just ordered one of these balancers today.
Dual key, never been an issue before.
put some heat on it
That is the next step. Just waiting to talk to IW tomorrow.
Billy:
Already tried, with a breaker bar on both ends. My 200 lb son on one end and my 200lbs on the other. And with the impact on one side with a bar on the other. Shit was about to break! It is seized for what ever reason.
Department Of Boost
Alpha Geek
Dayyyyyuuuummmmm. What a boner. I'd be cutting it apart at this point.:chainsaw:
05stroker
Bullard Tx.
Im calling Brad at IW tomorrow and if he can sell me just the hub then that is the plan. If not then I will have to just suck it up and cut the whole thing and buy another. I already have two pistons and a set of rings on the way. I just want to put my eyes on it. Either way those heads will be off tomorrow!
psfracer
billy badass
Valencia, CA
Damn thats a huge bummer. Sounds like a real pita.
Never had the harmonic balancer puller not work before.
05stroker
Bullard Tx.
Its stopping me from diagnosing the motor to get it back to the track! The grinder is on standby! :thumb2:
RocketcarX
95% of my weight is fuel
Colorado
Can you post a pic? Never had a balancer not come off with a puller myself.
86GT351
Sunny South Florida
I have never had a balancer not come off either. Can you see into the center hub? Does it look like the balancer spun on the crank snout?
05stroker
Bullard Tx.
86GT351
Sunny South Florida
Have you tried to spray PB Blaster into the hub/snout area? Probably not going to help but you never know!
Fullboogie
King of the Ski - OG Jr.
Houston
You sure you have the pointy bearing on the end of the large screw so it can rotate? If not, you're threading it into the end of the crank.
05stroker
Bullard Tx.
Yep, going to disassemble the balancer and heat the hub with a torch while using the puller.
