Taxman
One foot out the door
DFW FTW
Finished up the install of my new FRPP wheel bearings with ARP lug studs. Used an open end but then capped it with black spline lugs so I wouldn't have exposed threads.
Taxman
DFW FTW
So the spline lugs are also threaded on the studs?
Yeah I put open ended lug nuts and torqued them all down, then capped it off with the black lug nuts. You can't even see the open ended lug nuts without looking closely.
GoneFord
Yorktown VA
Did you have to replace your bearings? If so what was your indicator? How many miles had you rolled up?
Taxman
DFW FTW
Yeah I had to replace them. There was a grinding noise coming from the wheel and when I jacked it up, there was some play in the wheel. Tie rods and ball joints were solid, so that left the wheel bearing.
yea, cool idea to hide the studs, more work if you need to take them off though... :crazy:
mikeysgt
Bakersfield, CA
I did the same thing to my car when I had longer studs up front when I was tracking the car. nobody even noticed the front lugs stuck outa little further than the rear ones and I ran them like that for over a year. I hated the exposed threads also
Bud
Northern Colorado
Sad day, put coolant in the radiator and flushed the a2w with RV antifreeze. Swap it over to gas tomorrow and it sits for 5 months over winter.
swedensky
Replaced the strut mount and control arm..wish I had the funds to upgrade and not just warranty replacement.
