Not sure how much it goes into the thought process for a swaybar, but hollw would be stronger torsionally than a solid bar. There is more surface are resisting torsion than a solid bar. Same idea applies to gun drilled axles. It saves weight, but makes the axle stronger as well
I thought the rear stock bar was solid?Come on now... Honestly who on here besides top racers( Terry, Sam, Whisky etc ) are going to be able to take advantage of the minimal weight diffrence? I weighed my rear stock bar to te Whiteline unit and I think it was like 1-2 LBS. if you want to loose a couple pounds take a big crap before you hit the track.
Who cares if you can "take advantage of it"? Why would you buy something heavier and more expensive given the choice?
I understand the reason for going with the Whiteline rear bar to get more clearance but this top racer stuff is bullshit. A lighter set of bars is clearly more desirable. AFAIK there is no advantage to using the front Whiteline sway other than to have matched set and you really needed the rear Whiteline bar.
Just because somthing is lighter does not mean its always better. I learned that road racing bikes. You can put lightned parts on your car all day long and when you ACTUALLY start beating on your car at the track usually the first things to break at race pace are the lightned parts. We built titanium this and titanium that for the bike and yes she was light as hell. 370LBS ful of fuel and 191hp at the rear tire an you want to know what started breaking first.. All the lightned stuff. We took the bike to the Isle of Mann and I made 3 laps and stuff started breaking. We had to replace parts with heaver stock parts and purpose built heavy parts just to make it around and the weak part wound up being the hot rodded lightned motor. For every hour of rideing/driving you will have an hour or more of maintance. Just because it's light does not mean its better an when your crusing around at the local hangout with your light parts an blasting the highway your not going to tell 1 bit of diffrence. Sams bars are top notch from what I have been told. The Whiteline front bar also comes with adj end links, lateral locks and is 4 point adjustable. You don't need extra clamps because the mounting points flex until you get a brace put in and the BMR raid mounts bend from what I have read but I think they have fixed that by adding bigger gussets. The point being if your running around on the street with full interior, AC yadda yadda yadda how are you going to tell the diffrence between a hollow bar and a solid one? I will tell you how... In your mind. It's not going to turn in faster, ride smoother, take 5sec off your time from McDonalds to WalMart it's all in your mind. Now I'm not saying that's what you do or how you drive I'm just using this as a reference. Theirs other ways to take weight off the car but then that depends on the orginasation and class your racing in. Look at Terry's red car. Whiteline everything, full interior, AC and he is still podium at national levels. Sam is the same way but how can you sit here and say that we could tell the diffrence. Take the front seat out and replace it with a Carbon Kevlar Sparco unit and you take MORE than the front and rear bars combined out of the car and tell me if you or I could tell the diffrence. Terry, Sam, Whiskey etc could but you or I doubt it.
I would think we could leave peoples driving skills out of the picture and talk objectively about tech instead of kiss assing a bunch of your favorite drivers.
Its supposed to be a forum to educate each other to better ourselves.
Breaking a sway bar is out of the question, unless you hit a wall or curb.
This is the whole game of racing, trying to go fast a possible. Eventually yes you break something. It happens to the pros, but sitting here telling people youll never get the performance out of a part is silly.
This is the corner carvers forum not some concours trailer queen parade.
No one is ass kissing anyone. I am giving them the respect as a racer they deserve. As for driving skills I was not talking about his, yours or anyone else's I just pulled it out of the air.
And again, yes you kind of did imply it when you brought up your titanium IoM bike failures. While I agree that lighter is not necessarily better, there was no reason to even bring up the example unless you were trying to imply that a tubular (lighter) swaybar may have the same durability issues. With the wall thicknesses needed to give the correct "spring rate," there's no chance that simple use or basic track abuse will cause it to shear in half.[/quote]As for breaking a bar I never implied a hollow bar would break. Never even heard of a bar breaking, bending in a crash yes but not breaking.
Excepting the last one, all very good reasons to buy the Whiteline setup. "I already had all the rest of the parts" to me is never a good reason to just pony up for something blindly. Wile I don't (yet) have any Whiteline parts on my car, I have suspension components from Freedom Racing, Steeda, Strano, Maximum Motorsports, BMR, AST, Hyperco, FRPP, etc. Why? I assessed each individual part as they related to the whole system, and chose what I thought would do the best job.The reason I chose the Whiteline front bar was price, adjustability, end links, lateral locks, customer service and I already had all their other parts.
