05stroker
Never enough power guy!
First off let me say I am open to all comments and criticism here.
Okay, so I have been looking at my setup in depth today as far as where I can gain some power while the motor is down. I have decided on a Manley 11.6:1 flattop piston. I will be pushing 23 to 25 psi along with it on E85.
From what I understand a motor is like an air pump, the faster the air can get in and out the better. I have no experience in porting heads but have the resources to do the work by hand. I currently have a set of basic ported heads from Kuntz Racing. They have stock size inlets and outlets while the ports are smoothed and have the 1mm oversized valve with bronze guides spaced properly.
I was looking at them today with the marks from the intake, exhaust, and cylinder bore still on the heads since they have not been cleaned up yet. Well, that has led to a lot of questions.
1. Why not open the intake as large as possible with the boost I will be running?
2. Why would I keep the exhaust port smaller then the gasket?
3. Why not port match the exhaust port to my headers?
4. Why is the exhaust port D shaped instead of round like my headers?
5. If flow is so important then why not open the intake port at the JPC intake and the head port as big as I can and then port the delete plate to match?
Here are a few pics to explain what I am thinking about doing. I would be machining the delete plate to remove the grooves for the factory style gaskets and using a dual gasket setup like the one below that comes with the JPC intake. Doing this would only limit the size of the intake port to what the head can withstand and not need to worry about gasket placement. It would remove about 5mm from the plate so, I will have to check for any interference with the alt. and such.
I would also like to remove the material in the combustion chamber much like the FRPP heads.
You have to keep in mind, this would be a custom setup geared towards my car only and not something that is produced for the masses.
