NUTCASE
The C&C where I am, in the spring/summer you are lucky to have a parking spot by 5:45a
and they thought I was crazy leaving my house at 5AM sharp to get a spot in line for IvD at 8am. I was still halfway back LOL.
lethe
V4g!n@ #er
Everett, Wa
And? Did the issues disappear?
Spools faster than the comp but not by much. I jumped up to a 7475 so i wasn't expecting it to spool as fast as Fuels 6765. It pulls noticeably harder at the same boost pressure so it's definitely moving more air.
lethe
V4g!n@ #er
Everett, Wa
What about backpressure? Didnt you have an issue with too much?
Also interested in the new back pressure numbers.
I never did measure my back pressure. I thought someone else on the forums checked their back pressure with the comp 6765. I assumed that was the issue since i saw a drastic improvement when Fuel lent me his turbo. I put the comp back on for a few days afterwards and had the same slow spool/lag. I Still don't think there is a issue with the comp turbo itself. It just doesn't seem to work well on our cars.
Jeffk
Thomasville, NC
I installed the new rear SR performance springs and changed out the rear gear oil. Man I hate that smell!!!
Sent from my SCH-I535 using Tapatalk
lethe
V4g!n@ #er
Everett, Wa
Changed the spark plugs,oil, and oil restrictor fitting on my turbo. Then i turned the boost up to 17psi and attempted to get a data log for lito but it's too wet out. It just ends up blowing the tires off and gets sideways at 80mph. Not much fun in the rain.
