When you launch hard (or only accelerate mildly, for that matter), you put the LCAs in compression and the UCA in tension.First off you need to tell me what would cause the axle tube to twist. I can't figure out that part. Does the axle shaft inside all of a sudden swell up and lock on the tubing, creating a twisting force on the tube?
Guessing the lower the arms are in relocation brackets the more likely the tubes are to twist then?
Oh crap... I've noticed caster issues on my car since I put on Bmr relocation brackets and stallion lca's... I also just replaced factory diff which was destroyed with a true trac. Is there anything that can be done now? I thought maybe something was just out of spec with my brackets or lca's and I was gonna get adjustables to remedy the issue. Haven't noticed anything weird except the caster being off...I just had the rear rebuilt and the guy who built it didn't mention anything about being twisted. How does one go about checking for a twisted axle tube and is it fixable? Am I screwed?
yea something happened around 6:15...Did you guys see where the American Muscle project car spun the axle tube in there latest video?
3v ftw!!!! lol
Yup, that's a twisted tube.
If only some company that produces beefy metal and already has a good idea for a working axle tube brace could produce one.Yup, that's a twisted tube.
Id buy it!! Seriously though, After watching that video of just a bolt on car spinning the tube, Im scared to run mine with some bias plys on it with out welding them.
To bad am didnt show damage on axle. Im guessing rod end on lca broke first and allowed the axle to twist. No rod end junk for me
No. If the rod end failed there would be no force trying to twist the driver side axle tube.To bad am didnt show damage on axle. Im guessing rod end on lca broke first and allowed the axle to twist.
