For those familiar my car is cranking, not starting and soaking the plugs. I ruled out the throttle body for sure. Next thing was checking for spark. I pulled all the cop connectors. The red wire to all the cops has 12v via my voltmeter. One lead to the red wire, the other to ground and showed 12v. Then I placed both voltmeter leads across the COP connector, had my son crank the car and I got absolutely nothing on the meter. First off, I did the correct procedure to check for this issue of no spark correct? Secondly, other than a PCM issue, what else could it be? Is there a fuse in the electrical distribution center?
Thanks guys.
Thanks guys.
