Project Large Caliber - Cam's NEW 2009 Bullitt Build Thread
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
So I did some other things today.
Looked at the wiring diagram again, and came to the conclusion that I'm a retard. The line I couldn't figure out went to the positive terminal on the battery. I was really confused because on the newer cars this line comes off the fuse box.
Decided to install the FRPP rear sway bar.
Hooked up to IDS. DTC codes galore.
Also working on fitting the Hurst stick to the MGW shifter. The GT500 shifter is a little different from the 3V, and I'm having to modify the stick.
Grinding it down.
Wired up and tested the HE fans.
Temporary lines, I'll cover them up when I finalize it all.
For the time being I have it wired up to an eyelid on the fuse box.
Running down the driver side to the dash. Ground is connected to frame.
Pulling it through the dash.
All wired up. Works great. Will be mounted above the headlight switch.
quiksilver15
Houston
Stock. I ran through all the ideas, and nothing is more appealing to me than the stock look. It's simple, and will bring out a surprise to any bystanders.
Bad ass man, I didn't like any of the other ideas personally. Widening the rears with some 335s like above would be sinister.
The stock Bullitt wheels are $234 each from Tasca, 18" black bullets are about $100 less. Buying a couple and sending them off to have them widened would be a lot cheaper than buying a full set of wheels. At some point I figure I'll end up doing just that.
GallopingFord
Northern Virginia
I will look into it as I progress. I want to get the car running, drive it this summer and then next fall I'll go more in depth. :thumb: I have 2 brand new Bullitt spare wheels in storage. I bought them when I bought the car. Lol
SGTguy
Springfield PA
Stock. I ran through all the ideas, and nothing is more appealing to me than the stock look. It's simple, and will bring out a surprise to any bystanders.[/QUOTE]
You made the right choice, now let's get this bad boy done.
GallopingFord
Northern Virginia
Did a small amount of work today.
New Brembo brake rotors showed up. Waiting for the pads now. The weather has slowed a lot of items lately.
Redid the wiring for the HE, to incorporate a relay. Fitted the relay under the dash for a clean install.
Waiting for crinkle wrapping to run around it to clean it up.
and while I was mounting the relay under the dash I dropped a bolt under the carpet. When I reached under it I found this...
I am 99.9% positive this is the culprit behind the why my car fob has been shorting out the electrical when I've been hitting the unlock button. This started happening when I had the aftermarket alarm removed. I ran it to behind the SJB, but have absolutely no idea where it is suppose to go. I'll look it up later this week when I have some time. Really pisses me off now I need to correct this.
Congrats on finding that wire. Poor workmanship can ruin a vehicle. It's not just the immediate results but the long term consequences that can really irk you. You'll be happier with the car now that the rogue wire has been uncovered.
GallopingFord
Northern Virginia
I agree. I've actually been on the hunt for that problem for a while. It was so frustrating to unlock the car and then it would remain unresponsive for 30-40 seconds. I'll look it up though and get it sorted out.
Jeffk
Thomasville, NC
WTF? Some people should just never touch a car! Hopefully fixing that will get rid of your issue.
Your work is looking good Cam. Can't wait to see the final product.
GallopingFord
Northern Virginia
Yup, we live and learn though. I learned the hard way many times with this car why I should only be the one to work on my cars.
I'm excited to finish this too. I'm going to be daily driving it a ton this spring/summer. I might even drive it to NC to visit friends in April. I do plan on taking this car instead of the convertible to Mustang Week too.
Update:
-Got a call that apparently the GT500 fuel pumps are on back order or something - who has them in stock and can ship?
-Still waiting for a headlight harness
-Looking around for a good deal on a 13' C/F driveshaft
-GT500 battery tray was ordered off eBay.
-TB should be here this week
-Still need gauges....
Found a midpipe that I'll be picking up in March (moving GF) and I'll be making a bunch of pit stops to buy parts off people lol.
I expect to fire it up that week of the 10th when I get that installed.
Does anyone have pictures of how they relocated the horns on the frame rail? Looking to install that just to get it out of the way.
Probably a couple other things I'm missing, but
19COBRA93
Ford Racing
Clinton, Ut
Cam, I have a pump kit here I can ship out today. You don't have to buy it from me, just ship me yours when it comes in and we'll be square.
It's the M-9407-GT05, correct?
GallopingFord
Northern Virginia
Hell yeah can't wait to see it this summer man
I expect you to be rocking that DoB manifold by then! :clap:
Yeah 2005-09
You have a PM inc.
