W3bb3r04 build thread
W3bb3r04
Slow 3v Member
Clinton, TN
Right! Forgot you were planning on running corn. What kind of numbers are you expecting?
I'd like 700 but my maf will be maxed out before then and the turbo will be too, so ideally, 600-650. Should be able to run less boost too. I'll be in the 15# range
W3bb3r04
Slow 3v Member
Clinton, TN
I figured out the missfire. It was a plug that looked perfectly fine just a little white on the ground strap and electrode. Bought another new plug and started changing them out one by one and finally got it. Whooo hoo!
Shotokan1509
CT
What exhaust do you run? Heard turbos really quiet it down but yours sounds good
W3bb3r04
Slow 3v Member
Clinton, TN
Thanks guys! I'm definitely glad it's running strong. Did some 5000 rpm WOT pulls and logs today and it is strong even with the AFR at 10.8-11.0. I can't wait to lean it out some.
i am ryan
Nashville, TN
Don't believe you. Gonna need some videos to confirm.
