Mild hesitation at throttle tip in
Fullboogie
King of the Ski - OG Jr.
Houston
I've been chasing this for a while now and I'm at my whit's end. Maybe some of you guys will be able to help.
Particularly when cold (but it does seem persistent to some degree when warmed up), at light throttle my car experiences a brief hesitation between 1,800 and 2,200 rpm when accelerating. It's just the briefest of hesitations, but I cannot find the cause. Plugs are new, MAF and filter have been cleaned, throttle body is clean. I've logged spark, fuel pressure, FP duty cycle and misfires, but don't see any anomalies in the datalogs in that rpm range. Funny thing is, this problem has been there across 6 Lund tunes and 3 VMP tunes, so it isn't tune related. The only thing I see when this problem occurs is a slight lean out on the wideband, meaning it will briefly go lean by a few tenths of a point then immediately jump back to normal.
It seems to be related to throttle position, because if I am just a little more aggressive with the pedal when accelerating through that rpm range, it goes away. Can a "bad spot" in the TPS cause this? I'm using an older 63.5mm throttle body that came with electronics (this is an '07 GT500), and I'm wondering if there's a glitch in the sensor.
Any ideas what could cause this? Or is there something else I can datalog that may show what is causing this? Any help is appreciated, guys. Thanks.
Timmbo
TN
Lund and I went through this on my Mammoth. I know you've dealt with Lund but I would request that he add a slight percentage of Transient fuel at tip in. It solved my issue.
86GT351
Sunny South Florida
I would also suggest addressing the tune. Remote tuning is not 100% exact science. Even with you providing proficient data from logs, the slightest adjustments can still be made. Have to remember that remote tunes are just that. The tuner does not have the car with them and can't feel what you are.
eighty6gt
I have this exact problem as well, my car will go lean off of the charts. Have sent logs to Justin. There's something with our setups and the MAF/Failed MAF tables (?)/lost fuel/? that may be causing it. I just drive around it. Justin turned off some adaptive learning at the affected RPM's in a tune he wrote after getting the logs, but I'd rather have that on since it seems like my car does learn after the weather changes. I drive it year round, from -40 to +30F.
Not a huge issue. I'll see if it persists after finally getting the 1.9.
eighty6gt
Definitely gets much better after warming up. I hesitate to say it's fuel condensing on the port walls, as the injector has a very straight shot to what will be a very warm combustion chamber. A tuning book I bought mentions this. Maybe I need to spend the big money on calibrated success by boom boom banish!
