JeremyH
3V Fuel Guru
Not normal, looks like seals are done in the blower.
I concur, seals letting oil by and the blower pushing it down the pipes with the air.
You're basically feeding your engine an air/oil vapor mist. LOL
Your not understanding a breather setup, there are no hoses on the intake or manifold to pull any oil vapor in. The breathers on the valve covers vent crankcase pressure under boost and keeps oil in the case where it belongs, then you cap the intake/manifold so no vac leak.
I know the op is trying to be comical about it, but you can seriously blow your motor with that much oil going through. The oil vapor will dilute your air/fuel and if your blow through you will get oil on your maf messing up the signal.
Def. oil coming through the seals, or being drawn into the intake attached to the blower from the valve cover. My Vortech has minor residue in there but not quite like that.
^ I think it's oil fed, not self contained.
Well seems to be a seal. Anybody ever replaced the rear seal themselves? Or front?
I've read where some guys say the rear seal is the same that you can get at freakin the parts store for like $10? Crazy.
I plan on just doing it myself and posting pictures on how to for reference for others
