Is anyone here running the PAC nitrated springs? There create a higher seat pressure then the regular PAC springs and I'm using them in my build. I figured with running the F1R at max psi pump gas can handle and running it up to 7k I would need the stiffer springs.
So my questions are, will the stock followers be more likely to break? Has anyone here had broken followers and what was the cause?
I car was started for 3 secs and all hell broke loose.... Follower broke in half and bent four valves. :-(
