Throw that bitch on youtube.
It worked for me, but I have an awesome computer.
Good job Kelly, appreciate it. One question...you state to have the weight of the vehicle on the tires. Is there a difference if the weight of the vehicle is on jack stands with the rears under the axle and the fronts at the jacking points as long as the vehicle is level? Thx...
Yep, that's why I asked. Short of being on a drive-on lift or ramps, I'm winging it.
It didn't clear up my vibration at 80, but it sure did get rid of those clicking u joints!
If you have a stock 2 piece shaft do you take your base measurement off the rear shaft instead of the trans flange or does pinion angle not matter too much with a 2 piece shaft?
