Special tool for installing Harmonic balancer?
hamish
B.C.
I need to pull the balancer to remove the front cover.
There is a ford pn for an installation tool.
Do I need this, or am I o.k. with a puller installer kit from OTC or similar?
hamish
B.C.
So I will have no issues installing it with these kits?
fdjizm
Drag Queen
I just installed mine steeda UDP with a long bolt till it seated.
Then put the new bolt in and tightened er up.
hamish
B.C.
I guess I could use the stock bolt and some washers to push it in.
fdjizm
Drag Queen
It's not pressed on there by a 3 ton machine it's not that hard to get back on, couple turns with a bolt and you'll have it seated.
hamish
B.C.
Might give it a try.
I have to buy the remover anyway, just had to justify the cost of the installer.
No one has the installer in stock anyway, guess I'll get the remover and try your bolt method.
onehotpny
Aragon,Ga
don't buy a pulley puller , just go to auto zone and they have them in there loan a tool program, all you'll have to do is leave a deposit on the tool,then once you bring it back they will give you a full refund.
hamish
B.C.
Northern Canada....No Autozone.
I would if I could.
bjtheman1
I ended up buying the tool to remove and the tool to install. Wasn't too bad just a tight space to work with for me.
AutoXRacer
Florida
Do not use the stock bolt to install the pulley!!! It is too short and some have damaged the threads in the crank!!
You need a slightly longer bolt than the stocker.
lenko
Alberta
Installer Crankshaft Vibration Damper
Hamish, I sent you a pm as I have one of these special tools if you are interested.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
A 3 jaw puller can get the job done on the stocker. I bought one for $15 at Princess Auto (Canada's version of Harbor Freight) and it worked no problem.
Another way to get it back on is to throw the balancer in a pot of boiling water or in the oven at about 200 F and pop it on before it cools off. This one can be a bit tricky but usually works.
RED09GT
Come on you Canucks. Canadian tire has the loan a tool program
Pay for it. Use it. Return it and get your money back.
They don't have the correct puller for the balancer, I tried that once. They probably have the correct install tool though.
awesome autocorrect malfunctions brought to you by tapatalk
fdjizm
Drag Queen
Yes.. it's called a longer bolt. lol I think I paid $1 for the bolt.
hamish
B.C.
I know but the closest one to me is full of retards and they just don't have the tools?
I don't mind gathering a tool collection, I am picking up the remover tool today.$30
