one eyed willy
Pizzle fo shizzle
Heard it been talked about, not sure when it's needed. My car is lowered with the air ride but my "driving" ride height is probably 1.5" lower than stock.
It's been aligned at "drive" height, but the steering seems to ultra-sensitive at high speeds going around corners. I know with the air ride I don't get the weight transfer I used to get when cornering, but I'm talking about if I'm just on the interstate, going fairly fast, coming up to a wide sweeping corner. Feels like the car wants to drift outward as I turn the wheel slightly, so I increase the steering then it feels like it wants to cut inward rather quickly.
I have a few different things I could adjust on the air ride, rebound and ride height . If I raise the coils I could lower the pressure in the bags which may help with the weight transfer.
Before I start making adjustments, I'd like to know If I should do a bump steer kit so I can do everything all at once.
