How Much Does It Weigh?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Based on the recent interest in weight reduction, this thread is intended to be a clearing house for all things related to shaving pounds off our cars.
If you have actually weighed a part, post in this thread and we'll keep the list here in Post #1 updated. Let's also add aftermarket replacement parts, so we can see the difference between stock and its replacement. Please don't "guess" on the weights... that won't help us. Unless you actually put it on a scale, keep it to yourself.
Also, if you notice any errors in this spreadsheet, post them up.
Matt-D now maintains this list, and he will making updates to this spreadsheet as often as necessary to keep it current.
UPDATED 02/02/2010, 6:08pm PST
Matt D
S197 Pilot
Toronto,Canada
I will add a bunch of numbers to this tomorrow, I have a hand written sheet sitting in my car :)
thanks for the sticky Don
psfracer
billy badass
Valencia, CA
Stock front strut assembly with stock brakes and calipers = 67 lbs each, 134lbs total
Door assembly with trim and window / electric motors (but does NOT include stereo speakers and wiring harness) 81lbs for each door. 162 lbs total. Speakers accounted for in weight of stereo.
A/C system, compressor, condensor, lines. 38lbs This was hard to weigh as the lines and stuff were very bulky. I threw everything in a tote and weighed it---then just weighed the tote by itself and subtracted to come up with the difference.
Shaker 1000 stereo system complete 85lbs
Wiper motor and wiper blades 9lbs (does NOT include washer fluid or washer fluid tank)
Passenger side air bag: 7lbs
Passenger seat (no air bag, no power) 48lbs
Will weigh driver seat (with power) tomorrow, want to confirm the 60lbs, could be +/- a few
Will weigh driver side air bag, stock hood, stock k-member with a-arms, back seat with brackets, seat belts.
usmcpony
I wanted this to happen. I didnt think anyone would actually weigh everything. Thanks for stepping up to the plate.
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
what are the axle tube weights that are listed?
9 lbs OEM axle tube weights (pair) <---- these ? if so ford added weights to some of the cars to help with noises fro the rear end , basically another trick to shut it up lol they are pictured here outlined in the red boxes
Enitalp
The lost guy.
Canada, QC
Gone. i'm pretty sure that's the easiest weight saving on our car.
I didn't see any noise difference.
Matt D
S197 Pilot
Toronto,Canada
I weighed some of the same things paul did with some differn't results... I guess no two scales Are exact but here is some of my info... Just a bunch of stock weight numbers and after market, I will keep adding to this post , so keep posted!
Stock Parts
All parts out of trunk/ Sound detonating 42 lbs
Complete Ac system 33 lbs (not including underdash only in engine compartment)
Stock hood 30 lbs
Stock trunk 23 lbs (with no wing)
Back Seats top and bottom 21 lbs (not including hardware for belts)
Rear seat belts, brackets and bolts 9lbs
Front seats with rails –Pass side 42, Driver side 50 = 92 lbs
Stock rims/tire (51 pounds each) 204 lbs
Stock rear lower control arms 12lbs
Stock Oem windshield 28lbs
Stock manifolds 20 lbs
Stock h-pipe 32 lbs
Stock sway bar 13lbs
Sway bar brace 16lbs
Wind sheild fluid tank (full) 8lbs
Small plastic piece (stock belly pan that connects to rad support) 1 lb
Stock k-member, a-arm, motor mount assembly 68 lbs
Parts you will be adding or replacing with, so you can do the math with the stock weigh figures and get your total weight savings.
Granetelli Sway bar Delete 3 lbs
Bogart 15x3.5 Bare rim with alum centre cap 11lbs each
Bogart 15x10 bare rim with alum centre cap 13 lbs each
Kooks long tube headers 16lbs (pair)
Kooks off road X-pipe 18lbs
Racecraft K-member, a-arms and motor mounts 46lbs
MMR Rear seat delete 9lbs (yes you will be adding 9lbs after you minus your seats and brackets)
Corbeau FX1 Pro seats Suade 16lbs each
Corbeau Seat brackets 9lbs each
Upr full race lower control arms 4lbs
buffguy
Anaheim, CA
I weighed some of the same things paul did with some differn't results... I guess no to scales Are exact but here is some of my info... Just a bunch of stock weight numbersand after market, I will keep adding to this post , so keep posted!
Stock Parts
You state the LCA to be 12 lbs, Don said 14LBs. Who is right?
Also I would like to add
stock front rotor - 19 LBS each
stock front caliper w/line - 11 LBS each
Matt D
S197 Pilot
Toronto,Canada
Well I have a few front oem windsheilds in stock , Im going to weigh one and then call speedglass to see how the weight compares... This might be my next big thing, to replace front,rear,both side doors, and the 1/4 windows
Matt D
S197 Pilot
Toronto,Canada
So the stock front windshield weighs 28lbs... i thought it would weigh more.
I assume the back weighs just as much.
I think if all the windows were replaced on the car dropping 50lbs might actually happen.. They are not cheap though lol but hey, what is?
Matt D
S197 Pilot
Toronto,Canada
Well I just got off the phone with speedglass.
They don't have the complete kit in stock to weigh each window seperate but they told for a 1/4 front windshield and all the rest 3/16 all the windows together weigh 40lbs....
Just some more info for you guys :party:
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
how much $ for the complete kit matt ?
Matt D
S197 Pilot
Toronto,Canada
well thats the exchange rate....... 1.30 so what ever is us price we have to add shipping, duty and exhange rate.. what happen to free trade xD
