How Much Does It Weigh?
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
it's right next to our free-dom lmao ok enough of my bs back to topic
che adjustable strut tower brace = 9lbs
don_w
Dyno Numbers - Who Cares?
San Diego, CA
You state the LCA to be 12 lbs, Don said 14LBs. Who is right?
Go by his numbers. What I listed in the first post was from somewhere else. I can't vouch for them. If someone weighs a part and it's different than what I had, then we will go with the weighed version.
matt texass
Well I just got off the phone with speedglass.
They don't have the complete kit in stock to weigh each window seperate but they told for a 1/4 front windshield and all the rest 3/16 all the windows together weigh 40lbs....
Just some more info for you guys :party:
I'm not real familiar with speedglass but is there any real downside to using it as compared to oem glass. Maby some kind of discoloration can it be tinted and such?
Matt D
S197 Pilot
Toronto,Canada
Im sure you cannot tint it, its made from plexy glass, but speedglass put some kind of coated on there windows so it does not scratch at all! It fits like factory, Vaugh Jr has them on his drift cars and so do alot of other drifters etc.
don_w
San Diego, CA
Thanks everyone. Keep adding to this thread, and I'll update the master list in a few days. :beerdrink:
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
GT500 Rotor: 25 lbs
GT500 Caliper (loaded, dry): 10 lbs
Weights are each, and about as accurate as you can get with a bathroom scale..
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
ok according to my niffy bathroom scale the steeda economy deletes weigh 4lbs even , the stock ones with motor,bracket,bolts weigh 5.2lbs so a weight savings of 1.2lbs lmao
Matt D
S197 Pilot
Toronto,Canada
whohooo :LMAO:
what ever at least it's taking something off lol :thumb:
usmcpony
I weighed some of the same things paul did with some differn't results... I guess no two scales Are exact but here is some of my info... Just a bunch of stock weight numbers and after market, I will keep adding to this post , so keep posted!
Stock Parts
All parts out of trunk/ Sound detonating 42 lbs
Complete Ac system 33 lbs (not including underdash only in engine compartment)
Stock hood 30 lbs
Stock trunk 23 lbs (with no wing)
Back Seats top and bottom 21 lbs (not including hardware for belts)
Rear seat belts, brackets and bolts 9lbs
Front seats with rails –Pass side 42, Driver side 50 = 92 lbs
Stock rims/tire (51 pounds each) 204 lbs
Stock rear lower control arms 12lbs
Stock Oem windshield 28lbs
Stock manifolds 20 lbs
Stock h-pipe 32 lbs
Stock sway bar 13lbs
Sway bar brace 16lbs
Wind sheild fluid tank (full) 8lbs
Small plastic piece (stock belly pan that connects to rad support) 1 lb
Stock k-member, a-arm, motor mount assembly 68 lbs
Parts you will be adding or replacing with, so you can do the math with the stock weigh figures and get your total weight savings.
Granetelli Sway bar Delete 3 lbs
Bogart 15x3.5 Bare rim with alum centre cap 11lbs each
Bogart 15x10 bare rim with alum centre cap 13 lbs each
Kooks long tube headers 16lbs (pair)
Kooks off road X-pipe 18lbs
Racecraft K-member, a-arms and motor mounts 46lbs
MMR Rear seat delete 9lbs (yes you will be adding 9lbs after you minus your seats and brackets)
Corbeau FX1 Pro seats Suade 16lbs each
Corbeau Seat brackets 9lbs each
Upr full race lower control arms 4lbs
Matt, I have read through most of your threads and noticed in your sig. you have reduced the weight by 300+ lbs. Have you weighed the car since you have installed all the mods? If so what did it weigh? Do you have numbers for all 4 corners? Do you have a complete list of your weight reduction mods? Thanks for the help.
Matt D
S197 Pilot
Toronto,Canada
I havnt weighed all four corners yet. Everything I put on the scale that reduces weight I add to the equation. If you go to my build thread it has all my tricks :beer:
Bogart rims and my mickey T's knock off just over 100 lbs alone
K-member kit
Sway bar delete
Ac system gone
Race seats
rear seats gone
gutted trunk
sparco steering wheel
etc etc
TheJimmy
whohooo :LMAO:
if thats truly the case im sure all the nuts that have the metal tabs could be replaced with regular nuts for another small weight loss
explict
Heavy Metal
Fort McMurray Alberta
Does anyone know what the stock radiator weighs?
And how much another aftermarket one weighs, for example fluidyne or something?
Snafu
Oklahoma
Any idea's what the steel door braces weigh? I know guys use to plasma cutters to cut them them out. Has anyone done this? They are the collision braces about 18 to 20 lbs ea.
