Currie 9" for S197 2005-2009
Born To Run
Woodstock,Ontario
I have for sale one Currie 9" complete with Currie 35 spline axles with 3" studs,Moser nodular iron centre section with 4:10 gears spooled,welded LCA relocation brackets.The housing was poweder coated black.I am the original owner.
This is a true bolt in mod with all the correct brackets,locations & geometry.
PRICE $1,500.00 i will meet at border,either Detroit,Sarina,or Buffalo
Born To Run
Woodstock,Ontario
Currie
what changes need to be made to the driveshaft?
It depends on what trans you have.The rear pinion is a 1350 u-joint on the rear end.Or you can change the pinion to match your driveshaft.If you have a 4R70W I have a Dynotech driveshaft that will fit.If not just call Dynotech & have a driveshaft made.
What trans do you have?
gil_t2
Love Nitro in the Morning
Northern Va
I have a 5R 55 and a spider shaft one piece aluminum shaft
Born To Run
Woodstock,Ontario
Currie
I would suggest ordering a new driveshaft from Dynotech.
Spydershaft made a good product,I had one(its a Ford Ranger driveshaft altered for our S197s I believe).You could sell it or keep it just in case you go back to stock someday.
irishpwr46
Official Site Vandal
NYC
i have a driveshaft that came out of a 9" rear end s197. originally belonged to 94tbird
Born To Run
Woodstock,Ontario
Currie 9"
TTT
