6060 swap and built 8.8
LBSRACING
Alabama
Located in Albertville, Alabama. Came out of my 07 GT Mustang.
Rearend has Strange 35 spline axles with c-clip eleminators, 3" studs, Strange spool, BMR relocation brackets, Bmr anti roll bar and BMR panhard bar relocation bracket and Moser cover. I did have to grind the abs rings to install new studs. So I you plan to use abs you will need new abs rings. Reareand also has less than 500 miles.Reason for selling is I put a glide in the car and a fab 9" rearend. Would prefer local pick up.
Complete Rearend 1200
johnnyv8
South Jersey
What kind of flywheel? 8 or 6 bolt? Aluminum or steel? Are there 500 miles on the clutch/flywheel as well? And are you willing to separate?
LBSRACING
Alabama
Dang I did forget that. 8 bolt billet steel flywheel. Fly wheel and clutch came as a kit. yes they have less than 500 miles to. This hole set up was behind my 5.4. Yes I would be willing to separate
LBSRACING
Alabama
Yep MGW shifter sold!!! I do have a stock shifter that I can throw in with the trans if needed
blownGTvert
Zeeland, MI
TR6060, shifter, crossmember
Im interested in the TR6060, stock shifter, and trans crossmember. I called D&D and they want $500 to go through the trans including replacing the syncros.
So what's the best price shipped to 49423?
Mike
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
If it's still for sale in a month or so I may make you an offer. I'm just not needing an entire axle to take up space I don't have in my garage lol.
