Gabe
Whippled Coyote
Took the front tires off my '13 to check for tire rub, since the 285's are not leaving much room, and was pleased to find no signs of rubbing on the right front, and only a bit of rub against the wheel well liner in the left front.
Also took the rear wheels off the girlfriend's Shelby and replaced the parking brake cable locks/clips. One was missing and the other was coming loose.
avinaj80
Fixed a nagging exhaust leak that sounded like a whistle. Forever though it was the clamps coming loose on my x pipe. No, it was the damn header bolts. 3 of them were hand tight... Time for some lockers...
swedensky
Finally had a friend get the fog lights working, but that caused my front turn signals to not work and my rears to not blink sequentially...so back to square one we go
Gabe
Whippled Coyote
Ordered one of these, for my upcoming T-56 Magnum XL swap.
For $159.95 shipped during their current Labor Day 20% off sale, I didn't wanna wait and pay more later.
attachment.php
TGR96
el blanco nino
Huntsville, AL
Did you switch from the grille mounted fogs to the GT/CS fogs? I'm curious, because I am about to do that swap.
EDIT: nevermind, I saw a pic of your car with the GT500 front end.
joe_momma
TN
Got new shoes put on...Michelin Pilot Sport A/S 3 in the stock 235/50/18 size.
joe_momma
TN
Since when did Michelin start making skinnies? J/k
LOL. They might as well be, the stock BFG wouldn't hook with my CAI/tune-only machine. Hopefully these are better in that department until I can afford some bigboy tires/wheels.
GreenTerror
Rogers, AR
Discovered that with my new suspension my floor jack can't get under the side of the car. So I fabricated two new mini ramps, I cut two chunks off a 2x4, and backed up onto those to get clearance. Then applied a custom paint job (duplicolor caliper kit) to my rear calipers, black to match the front Brembos.
joe_momma
TN
I have to drive up on a chunk of 2x4 to get my floor jack under the car since lowering too. How do you like the Duplicolor kit? I want to do my calipers, and am considering the Duplicolor kit or the G2 kit...
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Walked past it and got in my truck to goto work :(
Still sitting on Pro Radials with rubber stuck to back bumper :)
Makes me wanna drive it looking like that !!!
onehotpny
Aragon,Ga
Air lift box's arrived yesterday, but I've been sick with a bad chest cold, so looks like won't start the install till some time next week.
GreenTerror
Rogers, AR
So far so good. Its thick and goes on nice, I don't have any complaints yet, we'll see if it holds up.
