Travis R
I'm heading to a road course in a week, so I just installed a set of Hawk Blue 9012 over the weekend. Install went relatively well (had to rent a tool for the rear calipers). But once I started the bedding process there were some pretty terrible noises coming out of one of the wheels. It sounded like metal-on-metal grinding. The sort of noises I'm used to hearing if the pad has worn through to the backing plate.
I expected some squeaking, but not grinding. I actually took the caliper off again this morning just to make sure I hadn't screwed something up. Like maybe one of the little spring clips was in there wrong and rubbing against the rotor. But upon careful inspection everything seemed to be in it's place.
I guess I've never had pad with this high of a metallic content. Is this kind of noise to be expected? I'm also wondering if the noise will subside once they are fully bedded.
Thanks for any tips/reassurance you can give.
I got them to the point they stank & smoked. They have worked great since. IIRC, there was some grinding initially, but not after the bed in.
