Mineral_'01
- Joined
- Aug 24, 2014
- Posts
- 183
- Reaction score
- 1
DIY caster/camber adjustment and suspension setup ?'s
Hi, first post here. I have a few questions for you HPDE/track guys. When you guys make a suspension change track side or in the garage, what are you using to dial in your caster and camber. I.E. digital caster/camber gauge, just eyeballing and evening out your CC plates, etc.
I have a boat load of suspension parts to install on my '14 TP over this winter (leave from deployment) and I want to dial in my own alignment specs, except for toe, in preparation for some HPDE events next year.
My setup will consist of Ground Control coilovers with their street plates and I just don't trust my local alignment to do custom specs. I was thinking of purchasing a digital acculevel caster camber gauge by Longacre and a set of Fastrax no-lip adapters to align it myself during the suspension install.
Last question, what would be a good starting point for stiffness (which hole) with the Strano front and rear bars? Again, the setup will be with GC coilovers set to about ~1.2 drop front and ~1.5 rear. Spring rates are 430lb/in front 225lb/in rear. I will be running the stock P-zeros (255) over this winter until I purchase and install a square set of nitto nt-05's 285mm next year on wider wheels. I was thinking of starting with the middle hole for the front and full soft in the rear. Looking for a pretty neutral balance with maybe a little bias of throttle induced oversteer.
Sorry to sound like a noob, just really getting started with performance suspension setup. Any help would be greatly appreciated. Thanks
