Mineral_'01
- Joined
- Aug 24, 2014
- Posts
- 183
- Reaction score
- 1
So I've been obsessed lately with ideas on how to improve on DIY alignments other than an expensive Longacre caster camber gauge (or similar) and the string and tape method for toe.
The Longacre CC gauge is nothing other than a cheap digital inclinometer and wheel adapter that they charge a lot of money for. You could build one yourself for a lot cheaper, but I am looking for ways to improve upon a single axis CC gauge like these.
This led me to think about using some kind of dual axis gyroscope inclinometer to make setup even easier and more accurate. So I did some digging and found this: http://store.drpperformance.com/dual-axis-dynamic-caster-camber-gauge/
This is exactly what I was referring to for a dual axis gyroscope inclinometer. Again this company wants a lot of money for this rig when you could duplicate it yourself for under $100 using this: http://www.amazon.com/Function-DXL360S-Digital-Protractor-Inclinometer/dp/B00C3XKZ98
Look familiar? And only $75
Some video of this thing in action:
https://www.youtube.com/watch?v=v9P0QnlMkvI
So I was thinking using this inclinometer and a wheel alignment adapter fixture I could have a pretty accurate caster camber gauge for pretty cheap that would have many other uses for suspension setup as well.
So some questions; would there be any complicated math formulas to read caster and camber? Or just zero the meter at ground level and then take the readings once mounted to the wheel adapter? I wonder exactly how to measure caster like the DRP performance unit does using the same inclinometer? Anyone have ideas?
I even found another product that uses the same type of meter to measure caster/camber all in one kit. See here:
http://www.ebay.com/itm/FIT-TOOLS-W...1113897734&pt=Motors_Automotive_Tools&vxp=mtr
It incorporates my exact purposed setup with some kind of additional stand/fixture for caster measurement, but I can't really figure out how it works. Edit: after watching a video on this product, caster is measured by taking readings using the 20° sweep method. The extra stand is just a electric protractor notifying with a beep sound once you have turned the wheel 20° one way.
Finally, would it not be possible to use this meter to measure toe using the gyroscope function? (rotation of X-axis) Just zero it to your rear wheels, (these would already be at zero toe) make sure your front wheels are straight, and then compare measurements from the rear to front wheels?
