That's OK. Just know that the traction control works by grabbing rear brake, sometimes when you don't expect it. And it will grab often and hard enough that you won't have enough rear brakes to go home on, or maybe even not finish the day with.
Street brakes are easy enough to destroy on track. The traction control wears them out even faster. Just go into the event knowing that and plan for it - ie. bring another set of pads, tools and fluid to change brakes after the event so you can drive home.
, with the system turned off via the 5 second button press...
