Attn Drag Racers! Proper Burnout Technique
cm581978
NJ
Question for the drag racing pros, but what is the proper technique to do a burnout at the track? I will be racing on drag radials and am a total noob at this. Im quite worried I'll end up in the wall during my burnout:chainsaw:
fdjizm
Drag Queen
I'll be there to help you, You're not going to end up in a wall.
I shall learn you the brake stand, grasshoppa.
808muscle
Maui
I drive through the waterbox then do my burnout. I was told 40 mph 4-5 seconds ease off the brake roll out of the throttle. Auto trans put it in second gear. Manual idk but you need 40 mph to generate enough heat. Don't worry about it too much, you will figure it out. Don't sit in the water box and burnout. Water will get tossed all up in your wheel wells and drop down on your tires when staging. You will get better at it the more you do it. No stress, have fun.
dysan
Dis-Member
Williamstown, N.J.
Certain tires like different amounts of a burnout. The mt 275 pro's that i run now like just enough of a burnout where i start seeing smoke....The normal et street radials when i had them liked more of a burnout.
It's just going to take some trial and error.
irishpwr46
Official Site Vandal
NYC
second gear in a manual, not first, rev to 6k and dump the clutch. 50-60 mph until you start seeing a good smoke develop. usually about 5-10 seconds.
ArtQ
Alpha, NJ
Just a quick haze :thumb2:
picture.php
No really...Do it this way only if you're mad at your tires....
psfracer
billy badass
Valencia, CA
Watch the first few seconds. Notice the tach. PG trans, so when I shift that is equal to 4th gear. LOL. I am a very angry person.
2011/5.0
Iowa
Linelock is helpful also. My mt et street r like 5 sec at 50-60 mph in 2nd gear burnout
5.0 Probie
Puget Sound
picture.php
LIES! You just hit mach one. That is not tire smoke it is your car moving moister/air at a high rate of speed resulting in a sonic boom...
:nk:
cbass
Rochester, NY
Quoting so we can look back at this when either a) he stuffs it, or b) twists a tube after listening to this so-called "advice"
fdjizm
Drag Queen
My advice is solid gold bro, the execution of my advice however... that can vary per user :roflmao:
cbass
Rochester, NY
You know shit's going to be real when the first step is, "get a good, solid whiff of those smelling salts."
