got my DOB R-SPEC!
crownaviation
http://www.tudyno.com/
Broke dafuk down
Crown what kind of treatment does your front cover have? Matte black powercoat?
Yes
Took a few more pics today. Ready to slap the oil pan on and in she goes.
Almost looks too good to put in a car.
Put the dei wrap on. Amazing stuff.
I'm baffled trying to imagine how the belt will be routed without the water pump pulley. Can you please install the belt and take a picture?
crownaviation
Broke dafuk down
I am using the wp pulley. The r-spec is a dual belt system. Everything but blower uses stock setup if you want. Some guys run the dob/Eaton setup without wp pulley (obviously need electric pump)
crownaviation
Broke dafuk down
Thanks to devcon07.. Got some nice pics. Be is going to be mad for using photobucket and the poor quality. Emailed pics are like what you would find in a magazine..
Department Of Boost
Alpha Geek
I was thinking of doing that but there is something about it that seems not quite right. What does Lito think?
crownaviation
Broke dafuk down
Well, you see the flammable box in the background is back on the shelf lol. Unsuspecting pic but I suppose I look like a douche normally so there is that
Department Of Boost
Alpha Geek
Fore innovations f4i. Each rail has own port off the regulator
Do I understand this right?
You feed it with the line coming from the tank into one of the four pressure ports. Then you feed the rails using two more of the four pressure ports. You return fuel out of the port on the bottom. You plug the fourth unused pressure port.
Do I have that right?
What size thread are those four pressure ports?
