Bosch 1000cc injectors
Status
Not open for further replies.
rcm90
Alamogordo, Nm
I have a set of brand new Bosch 1000cc injectors for a coyote that I bought from Bobby@S&Hperformance. Selling because I'm going to need more injector.
$500shipped CONUS
justinsstang
Are these EV14? Wondering if these fit right on the 2014 GT since I'm pretty much talked in to the bosch 1000cc injectors now. Did some reading around and looks like it needs extension adapters or something or is that totally wrong? Free bump =)
JeremyH
3V Fuel Guru
Virginia Beach
@ 60psi would they support 1,000 RWHP Turbo on E85 you think?
They should be able to stretch to 1000rwhp on 60lbs of pressure.
Maybe. That's pushing it for my tastes. If you use a calculator with a conservative bsfc 60psi would yield around 1150cc per injector. I would want a solid 1300cc+ for 1000rwhp on e85.
They are ev6 taller injectors with uscar connection. They are Direct fit for 3v and coyotes no adaptors or extensions needed. So yes they would fit your 2014 and would be a great choice.
Ev14 are shorter height injectors with an uscar connection, they would need spacerss to run on a 3v or coyote. The gt500 and some other aftermarket blowers use the shorter ev14 injectors.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Pm me your paypal info I want to run these for now.
If I max them out later I will ass up the $1,300-1,500 for ID1300's but GD I can't swallow spending that much $$$ on GD injectors LOL
Status
