what is the rwhp limit on these with E85?
Depends on base pressure. They can run up to 6 bar (100psi). At 40psi around 850rwhp depending on setup bsfc.
@ 60psi would they support 1,000 RWHP Turbo on E85 you think?
They should be able to stretch to 1000rwhp on 60lbs of pressure.
Are these EV14? Wondering if these fit right on the 2014 GT since I'm pretty much talked in to the bosch 1000cc injectors now. Did some reading around and looks like it needs extension adapters or something or is that totally wrong? Free bump =)
