I wish man, I don't have them sweet ford racing socks!
That sounds like a great gift for the X Mas Exchange!
How does the flywheel look? Is it still attached?Well its not the starter, fuck me.
Same free spinning sound as before.
I'm not taking the starter back out fuck all that, can I do anything through the inspection hole?
Just did this, clutch out in first gear, rear wheels don't spin!Well you ruled out the starter, if you can't check the flywheel for forward to aft movement or to see if the ring is spinning, you can check to see if the flywheel is turning properly by putting the rear wheels in the air and put it in gear, short the clutch position switch and crank the car with the clutch up. Rear wheels should steadily spin while cranking. If they don't move its not engaging properly and there could be a flywheel issues.
I would also make sure you can turn the engine over by hand with a wrench on the crank bolt to make sure the rotating assembly is good.
