Starter took a shit this morning?
BadPiggy
Hooligan Ahole
Knoxville, TN
Hmmm...
Pull that starter and take a look at the flywheel teeth.
While you have it out, have someone turn the ignition over and make sure the starter gear is engaging.
That's all I got.
fdjizm
Drag Queen
Yes I'm rocking the OEM flywheel, is it pressed or some shit?
hammeron
was the oem flywheel ever removed then reinstalled? seems it came from the factory with locktite iirc.
fdjizm
Drag Queen
Yes a while back to get resurfaced.
A little more than a year ago.
hammeron
ok thanks. then i, must join those who say maybe the flywheel has come back far enough, that the starter gear can no longer engage the flywheel.
sorry to hear this, but hang in there.....this can be fixed, but it does sound like the transmission is gonna have to come down.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
You had the Trans worked on and/or Slave Cylinder changed(can't remember) but I bet the bolts backed out of the flywheel. I think you had FORD do the work. Tell them to FIX IT this time for free!!!!!
fdjizm
Drag Queen
Cars at the shop, verdict is in.
Broken flywheel/pressure plate, center part still bolted to the crank.
Off to the store for some preparation-H, merry fuckin christmas.
JeremyH
3V Fuel Guru
Virginia Beach
Sucks man, we need carnage pics though! You must drive the shit out of that thing!
Return that starter!
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Is this going to be your dime for the repair? In reading the previous posts it appears you had Ford do some work that may have contributed to the issue.
fdjizm
Drag Queen
Yes it will be on me, doubt I would win even trying to argue and I just want my shit fixed so it will cost what it will cost :mad2:
NUTCASE
damn.
mechanically the flywheel has made sense this whole time, but so doubtful because usually the clutch will slip before a flywheel breaks on these cars.
fdjizm
Drag Queen
Well it is the original fly wheel and has 7 years of clutch dumps on it.
I am going to swap in something beefier next year, I've been launching at 6250 lately, want to up it to 6500.
It must have been going for a while because I haven't been to the track in over a month and the car felt fine this whole time till the other day.
Maybe the cold finished it off.
AlbertD
Tucson, AZ
Sorry to hear about the failure, at least it didn't come apart during one of your launches though.
I had great luck with the Mach 400/Fidanza FW on my 3V NA setup. Took 6.5k+ clutch dumps like a champ for years.
fdjizm
Drag Queen
I was looking at the mach400actually.
Is the fidanza better than the exedy billet steel flywheel?
01yellerCobra
San Diego, CA
Ok. I wasn't sure if you upgraded the shortblock and that's the original flywheel when that happened. I have a Centerforce flywheel taking up space in the garage, but it's for an 8 bolt crank.
