05 mustang turbo
Wes06
you will need a forged bottom end if you plan to up the power.
but did you blow a rod? if you did you more than likely need a new block, possibly heads if the top end got damaged, find the damage you have and figure out how much you need replaced.
but the above post is a good deal
mustang 05
The moter is toasted I'm getting a hole complete motor bit it has 80 thousand miles and I don't know how it was driven that's why I was thinking about the up grade I don't want to push it to the max it is still a Daly driver just want the power when I need it just to play
Wes06
motor, whole, built.
please double check spelling, but yes rebuild it preferably with forged parts, and if you ask a question on here about how something will work listen to them.
the first reply in your first post called that the engine would blow
mustang 05
sorry I know that stuff spelling is wrong I just the first time being on any type of Ford forum or we can talk about anything with cars and stuff to build to find out what works and that I appreciate every bit of knowledge that I can and thank everybody to come here to be able to help me out make sure that the car is right when its done I will listen and obviously hopefully it works out
tjm73
of Omicron Persei 8
Rush, NY
I ovesly need it
You "ovesly" need one of these too.
05stroker
Never enough power guy!
Bullard Tx.
Are you from another country? This sounds like one of those threads where we find out layer the op is from a member that doesn't speak English or is from another country and then it is understood.
I speak Spanish but, you don't want me to try to spell in Spanish!
Wes06
Different county vs sheer ignorance of the English language as a first langiage are vastly different. I hope it's the former
weather man
Persistence Is A Bitch
MN
Guy fucked up...he is still here asking for help, bad speller or not, we should be able to extend help if he wants it.
05stroker
Bullard Tx.
Agreed, I was just stating that I have seen others do the same thing when posting from another country. I am no grammar expert by far! Lol
Plain and simple a startup tune is just that. Do not get into boost till tuned for it. 7 psi is enough to blow a stock shot block with a tune on it. Hell, most people only take them to 8-10 psi with a quality tune!
guys - simmer down, this is still in Tech - so lets keep on topic for the balance and end the bashing, the point is made.
saleen07gt
St. Petersburg, Fl
Like others said, you will need the correct start up tune, the correct injectors, fuel pump, forged shortblock, stiffer valve springs and a good dyno tune.
ECILOP4165
St. Louis, Mo
The tune is most important, when I put my CAI on without a tune my car wouldn't even stay idling, it would just die. I can't imagine driving, and on 7lbs of boost:wtf:
Live and learn pal, always always always have the correct tune
