james432
Dose anyone know if this aem 320 fits in the stock fuel hat?I been looking all over online nothing about it..
It's a replacement for your stock hat using the stock fuel lines.Yea I just want to do something in my stock fuel hat
GT500 pump is not just a pump but a complete system.
Dual pumps, a second Fuel Pump Driver Module (FPDM), and a wiring harness from the battery back.
I've been running a similar setup that Saleen had put together before the GT500 came out.
AEM is specific and recommends against using a BAP on their pumps? Their information page implies a voltage range of 12-18vI think I got a Walbro 405? You cannot use a BAP with these - interested for someone to confirm since I didn't realize S&H sold both. Seems like basically the same capabilities.
Ahh! Roger dodgerNah, but TI Auto/Walbro does:
"Manufacturer rated at 400 lph (Walbro / TI Automotive)
Operate under 14 volts only"
http://www.foreinnovations.com/product_p/w-f90000262.htm
My S&H pump was drop shipped from Fore.
I have two of those pumps getting ready to go in my GT500 hat but I aslo have a stock hat so I could try to see if it fits for you tonight if nobody else chimes in with some concrete information.
....just to add a data point....
I'm using a Walbro 460 from foreinnovations and the wiring upgrade (no BAP), and putting 597/608 to the wheels at 88% capacity (FPDC=0.44 at WOT 6.2k RPM)
Great results, sounds about right, that pump flows around 435lph which should 600 to the wheels no problem depending on setup.
