2012 Bay Area California Mustang 305hp HEAVILY modded.
Ike
Asking $15,800 obo
This car would make a great road race car, I drifted with it, went through 16 rears and 4 fronts. It has NOT been abused, and I did oil changes with ROYAL PURPLE every 3000 miles in the ~15,000 miles I owned it. I believe I am the second owner... maybe third.
Purchased from Dealership, and I've owned this car longer than any other.
Well over $30,000 into this car.
2012 Mustang 305hp HIGHLY MODIFIED
6 speed manual transmission
75k miles.
Black color paint underneath.
Missing side skirts.
comes with stock seats
Over $18,000 in modifications alone. Probably forgetting some here. Engine is stock except tune. Sounds amazing.
Brembo GT500 Big Brake Kit
18x9.5 Enkei PF01s all around.
275/35/18 Dunlop Direzza Zii Star Specs
Front flares ZG
2.5" Custom made front spacers to fit those 275mm front tires with steering angle kit.
Vorshlag Camber Caster Plates
Eibach Multi Pro R2 Coilovers Remote Reservoir Double Adjustable
Steeda Bumpsteer kit
Steeda Ball Joints
BMR rear lower controls arms
BMR rear upper control arm
Whiteline Positive Shift Kit
Royal Purple Synthetic Oil
Royal Purple Filter
Four stainless brake lines
Energy Suspension Bushings everywhere
Whiteline LCA Relocation Brackets
BMR UCA Relocation Bracket
Motul 600 Brake Fluid
Whiteline WATTS link
Carbon Fiber Ford Racing Differential
Modified Spindles For Drifting 62 degrees steering angle up from 42 degrees.
3M Vinyl Wrap Forest Green
BAMA iTSX tuner (will flash back to stock if you prefer)
Radar Detector Valentine V1
Bosh Wipers
Yellow LED fog lights behind grill custom wired to brights, look amazing!
Aluminum front grill
Comes with most or all of the stock parts also...
ALSO COMES WITH 4 or 7 EXTRA WHEELS... WITH TIRES. Or I can sell them separately.
This car is amazing to drive, no mechanical issues, low miles etc. V6 engine
It doesn't need to be smogged for ~3 years because it's less than 6 years old.
I've taken it to the track twice. Lots of fun.
650.924.931three
since it's not listed, this is a V6 car, you probably should specify that.
also all 2011+ cars a 6 speed, A or M
Ike
Yep, thanks edited. V6 6 speed MANUAL. Clean title. $30,000+ into this car.
