Squared tires on staggered wheels
o2sys
I currently have 275/35/20 all around on 20x8.5 all around.
I was on a budget at the time and got a good deal and the tires are brand new.
Now I want to change wheels again but want to get staggered 20x9/10 and run the same tires.
Does the width of wheel change the height of the sidewall of the tire?
mavisky
Atlanta, GA
I've done this before but only because I had a set of 275's on 9" wheels and then moved the rear to a 10.5" before the tires were even close to being worn down. Worked ok, but the rear tires had a stretched look to them and never looked as good as they did when I finally put the 315's back there.
Why not run a 20x10 at all four corners if the wheels you're looking at it allow? I couldn't be happier with my current square wheel/tire setup at 10".
o2sys
The wheels I want have a 37mm offset 20x10 not sure if it will fit. They are the super snake replica wheels
mavisky
Atlanta, GA
37mm should work, but it will be right out against the edge of the front fender. May want to run a little extra static caster to fit those. I think Cam is running a 20x10" +33 on the front of his 2013 GT500.
Shotokan1509
CT
They'd fit but may look bit stretched, you must be bulging with current 8.5's, most tire manufacturers would say minimum of 9, and they fit perfectly on my 9.5's (although I'd go tad wider in rear next time).
Also remember Ford did the opposite, staggered tires on same wheels for Gt500 255 & 285's on 9.5's
o2sys
Yea slight bulge currently but the tires I have (cooper RS3-S) are probably the narrowest tires I've seen for their sizes.
Jason09GT
Hewitt, Tx.
Hopefully it's ok to ask here, since it kinda falls in line with the OP.
I am wanting to step up to a 19x9 front, and 19x10 rear, and currently have a set of goodyear eagle's on the stock 19" wheels on my 14. I figure the front tires would be ok going on the 9" wheel, but what about putting them on the 10" rears?? I'm ocd as hell about front and rear tires being the same height, or within a un-noticable difference. I've looked at drag radials and the r888's for the rear, that are within .4 of the same height (rear would be shorter), but the price on those are through the roof. Would tunning the stock tires be ok for a little while?? Or best to sell my stock wheels and tires, and buy all new all around?
fast Ed
Caledon, Ontario CANADA!
245/45R19 would be pretty stretched on a 10" wheel ... Pirelli shows your tires going on a maximum 9" width as their recommendation. Those all-season P-Zero Nero tires aren't particularly fantastic, I'd suggest waiting until you can afford 4 of something else. 245/45 and 275/40 diameters would match, and be good sizes for 9" and 10" wheels.
cheers
Ed
Jason09GT
Hewitt, Tx.
Kinda what I figured. They are goodyear eagles, and actually hook ectremely well with my stock 5.0 m6.
fast Ed
Ah OK, I was thinking of the earlier cars that had the Pirellis when equipped with that size, didn't notice in your sig the fact that you have a 2014.
