325/30/19 tire
MELLOWYELLOW06
Los Angeles
I put it on an 11
From the sidewall, it looks small
attachment.php
But from the rear or mounted tread shot, it looks wide af
justinsstang
What are some lower cost wheels that they would fit on? I wish AM made the replica wheels I have in a 19x11 lol
MELLOWYELLOW06
Los Angeles
MRRwheels has a new wheel coming out called the M350, pictured above in a rotary forged so its light and strong and 19x10 and 19x11
attachment.php
Paul at Need 4 Speed is handling the preorder for these
http://n4sm.com/
Norm Peterson
corner barstool sitter
RIP - You will be missed
What wheel width would I need to run these?
http://www.tirerack.com/tires/tires...idewall=Blackwall&partnum=23YR9ECDW&tab=Sizes
I currently have 19x10 2013-2014 GT500 track pack replicas on the back and that's not going to cut it.
I chose this tire because I work for continental and I get huge discounts on all their tires.
Thanks.
A shame that Conti doesn't readily provide this information, but since wheel width range for any given tire size is fairly constant across tire makes and models you can use the information that is available for other tires as a guide.
What I found poking around at Tire Rack's specs pages . . . this size is intended to be installed on wheels anywhere from 11" (min-width) to at least 12" (the smallest "max" I saw, with some tire mfrs giving you all the way out to 13" wide). This size is measured on either an 11.5" or 12" wide wheel, this also apparently being somewhat mfr-specific.
