thump_rrr
Take a look at the J&S Safeguard Vampire.They left me a voice-mail. I typed this as I played it...they said:
"On the M142 alloy...9 pounds of boost would be no issue, we have guys running up to 15 on that. Now the issue is the 11.5:1 with the 9 pounds of boost on gasoline...we do not recommend that high compression with that boost level...now if you're running alcohol, guys have been getting by with it on alcohol. Not sure what type of fuel you are using, bu the M142 alloy is definitely a good alloy - SuperCobraJets run that allow on all the parts we make for those guys and they are having good consistence with that."
I think that is a good, conservative approach for a manufacturer to take...and I may well just put this build on the corn...but the more I study this, the more I think I'll be fine with 93 octane and reasonable timing of 17 degrees or so maximum. My tuner can keep my knock sensors enabled, and I also have a Snow Performance Stage 3 meth system on the car I can leverage...maybe I'll buy the safe-injection module that dumps boost (opens bypass valve) if meth flow is not detected.
http://www.jandssafeguard.com/VampirePage/Vampire.html
I'm thinking of going with one on my new engine.
