help me understand
SC boss
watch this!
Desloge Missouri
I have the moroso valve cover breather kit.
It is the catch can with a breather at the top. I crawled under the car today to drain the can for the first time and to my suprise was just what looked to be water? A very small amount at that. Is this normal? When the car is running I do see vapor comeing from the breather so is the can just catching condensation?
Thanks,
Shawn
SC boss
watch this!
Desloge Missouri
I have a hose that runs from the bottom of the can down bye my oil pan so when I change the oil I can drain the can as well. I was expecting oil to be in the can so my question is what is the can for? was I wrong to expect oil in it?
ROUSH1711
UNDER CONSTRUCTION
DE
Im assuming it hooked up correctly up top.
There may be some oil,depending on blow-by.
But if theres water,or slight water,I would want
to find the source. If you drive in the rain,you
may want to move the can higher up.Ive never
had any water from any catch cans.
GI Joe
Mine get water in it alot. Vapor...not a problem
SteveP
Modular Specialist
Boynton Beach, FL
I have one connected to my valve cover and blower. I see vapor coming up from under my hood when i stop. Its nothing bad. No worries. It's doing its job.
