saleen07gt
Now that the B53 is available, I've given serious consideration to the upgrade. I want a stout bottom end that will handle some boost, only problem I see could be the compression ratio, got off the phone with FRPP tech and it looks like the Mahle piston has a 10cc dish. If I use a 3V head, that could put the compression up there about 10.5 to 1 if I figured right, that might limit the amount of boost you can run with pump gas. Any input with this kind of compression or anybody running the B53 with boost ?
http://themustangsource.com/pri-201...-stroker-shortblock-and-aluminum-block-12066/
