Is there load on the linkage arm? If not I retract my critique.
Have a nice day.
There is zero load on the linkage rod. If there was it would actually cause binding.
George
Have a nice day.
i wish there was a race spec for the 05-10
we have looked into the 2005-2010 but the issue is placement of the linkage rod output shaft and the driveshaft location. they put in BEHIND the driveshaft so that funky offset arm is required. There just isnt enough room to make it work.
On top of that our newest 2014 revision of the 2005-2010 is so much more rigid AND you get the bonus of an adjustable patented throw feature no other shifter has.
George
The only thing I have to point out is that having a DS Loop mounted to the trans like that, is not a very good idea, IMO.
We have, and friends of mine have, experienced transmission tailshaft / housing failures....and it is not pretty if you do not have a properly mounted DS Loop. (according to NHRA, it must mount to the chassis via 1/4" thick crossmember)
NHRA said:Open drivelines passing any part of the driver’s body must be completely enclosed in 1/8-inch minimum thickness steel plate, securely mounted to the frame or frame structure. Driveshaft loop required on all cars running 13.99 (*8.59) or quicker and utilizing slicks; except vehicles running11.49 (*7.35) seconds or slower equipped with street tires.
I can't imagine it being "too much" in anything much short of an upper-level Lexus.I wonder how much NVH will be increased with this. I can see it being used for a weekend car or a purpose built car, but for a DD or moderately driven car I think it would be too much.
Victor
Had to dig back in the receipts to see for sure, but I also ran a Comp+ shifter (in a '79 Malibu), with my point being that neither I nor my wife ever noticed it to be noisy. Nor did anybody else who ever rode in the car, and it wasn't because of any loud exhaust system covering it up.
Norm Peterson said:...since the shifter is closer to the body it doesn't move in true concert with the shifter rod sticking out of the transmission, and in the 2010 and earlier years there seems to be a vertical offset that gets made up in the link between the shifter and the gearbox. I just can't get it out of my head that this will introduce a little undesirable shift rod rotation that either adds or subtracts from the amount you ask for at the shift knob as you go between the 1-2, 3-4, and 5-R gates. Dunno, maybe the 6060 and MT82 transmission setups are better off in this respect.
Norm said:The topics of longer throws and increased clutch effort levels on your '67 and my '79 (in all of its different iterations) are really separate matters as far as shifter NVH is concerned.
My take from that is if you need a near silent cab to pick up a hard-mounted/un-isolated shifter's contribution to cabin N and V, it really can't be adding much. Of course, however much it does amount to can be expected to bother some people more than others.I thought mine was fine too back then. Step out of one of those cars and into most any modern day performance car and you'll notice the difference, immediately.
My point was that you didn't really notice how bad the shifters were (in terms of NVH) as everything else in the driveline was just as raw. If you had a silky smooth clutch in your '79 along with a near silent cab you'd quickly find that the shifter/transmission stuck out like a sore thumb.
