lito
Dave, just the key on works, dont need the engine running.
There are two kind of X3s, your serial number starts with X3 or XP?
Yes
X3051##########
Ok, do you have access, by any chance to a 32bit windows PC?
I have an old desktop that is not in active use, I could set it up if needed I guess.
It seems it is for the GenII - as it loaded in Gen II but not 6.5Ok, so you have a config file already which I guess is for 6.5, correct?
and probably have a drive issue, have tried installing the device updater, it will install the correct drivers for old SCTs, the 6.5 will usually fail.
I did not install the device updater on the laptop, I didn't see any need for it, I have it on the desktop and it the X3 is up to date.
Are you suggesting if I put the Updater on the laptop that the driver issue could be resolved?
Try this if you haven't already. It may make a difference.Are you suggesting if I put the Updater on the laptop that the driver issue could be resolved?
