Running no rear sway bar on track?
csamsh
OKC
Yes, exactly. So if you increase rebound damping, it means that the front wheels extend more slowly, and therefore the contact force between the front tires and the ground is temporarily less than it would be with less rebound damping, and less contact force means less front grip, which means more understeer.
I would suggest testing it out. You'll find that more front rebound mitigates power on exit understeer.
Fabman
Children Of The Corn
Pleasanton, Ca.
This is what I have been able to put together so far.
Mustang GT (2011+) Stock: Ft 122 lbs./in Rr 154 lbs./in * Source, Maximum Motorsports
Brembo Stock: Ft 131 lbs. /in. Rr 167 lbs./in
Boss Stock: Ft 148 lbs./in. Rr 185 lbs./in
Boss LS Stock: Ft 137 lbs./in. Rr 191 lbs./in
Eibach Pro-Kit: Ft 159 lbs./in Rr 193 lbs./in * Source, Maximum Motorsports
FRPP K Springs: Ft 188 lbs./in Rr 221 lbs./in * Vorshlag Tested
FRPP P Springs: Ft 204 lbs./in Rr 165 lbs./in * Vorshlag Tested
FRPP T Springs: Ft 204 lbs./in Rr 221 lbs./in
Steeda Competition: Ft 225 lbs./in. Rr 185 lbs./in
Steeda Sports: Ft 200 lbs./in. Rr 175 lbs./in
Steeda Boss Springs: Ft 225 lbs./in. Rr 195 lbs./in
Steeda Ultra-lite: Ft 195 lbs./in. Rr 175 lbs./in
Eibach Pro street Coilover: FT 225 lbs./in Rr 90-200 lbs./in * Eibach Spec sheet
Eibach Pro R1: Ft 225 lbs./in Rr 250 lbs./in * Eibach Spec sheet
H&R RSS Clubsport: Ft 630 lbs./in Rr 515 lbs./in * H&R Spec sheet
H&R Race Springs Ft 325 lbs./in Rr 285 lbs./in
302S: Ft 600 lbs./in Rr 350 lbs./in * Official Ford 302S manual
KW V1/2/3: Ft 342 lbs./in Rr 200 lbs./in * KW confirmed. Rates are @ static load/ride height
FR500s Ft 500 lbs./in Rr 300 lbs./in
Roush Track Pac/KW Ft 515 lbs./in Rr 400 lbs./in * Unconfirmed by Roush or KW
Maximum Motorsprots Ft 320-360lbs./in Rr 260-380lbs./in
OEM GT ................L .............165..............L..................142
05-09
OEM GT Vert............L .............144..............L..................122
05-09
OEM GT ................? .............?................?..................?
2010
OEM GT Vert ...........? .............?................?..................?
2010
OEM GT500 .............L .............190..............L..................166
07-09
OEM GT500 .............? .............?................?..................?
2010
H&R Supersport.........P. ............?-275 ...........P..................?245
Steeda Ultralights ....L .............195 .............L...................175
Steeda Sport ..........L .............200 .............L ..................175
Steeda Comp ...........L .............225 .............L ..................185
FFRP K Springs* .......P .............173-239 .........P ..................195-236
Ebach Pro* ............P .............173-239 .........P ..................195-236
Ebach Sportline .......L .............Way Too Stiff, FOR RACE USE ONLY!!
BMR (pn SP009) ........P .............160……............L ..................140
CDC Ford Motorsport kit lowers one inch. front 185........rear 165
This is awesome, thank you.
Fabman
Pleasanton, Ca.
I think some folks are confusing swaybars with bolt-on chassis braces, subframe connectors, torque arms and other useless doo-dads. You can argue and calculate and quote Carroll Smith and postulate online but that still doesn't change the fact that modern cars function better with swaybars at both ends. Just like they function better with dampers on each corner, tires on each corner, and brakes on each corner. They aren't magic, but they are necessary.
There's always going to be less-than-perfect suspension advice out there, but we have to all be vigilant to keep from falling into the trap of "that sounds so easy and cheap that it must work!". Like disconnecting ABS systems, or thinking that there's a cheap way to make your brakes bulletproof, or that you can get great handling with Chinese coilovers, or that those scrub race tires you got for cheap are as good as new race tires. NO.
Carroll Smith was a great race car driver, engineer, and author. He died 13 years ago. I've read all of his books cover to cover, and much of it still holds true, but most of his experience and writing had to do with small, lightweight, formula cars. And even those still have swaybars. He was not infallible, and some of his theories have since been replaced with better data. Again, on the whole his writing is excellent and insightful, but it is starting to become a bit dated. 4 of his 6 "...To Win" racing books were written in the 1970s-1980s, and a LOT of automotive technology has changed since then. The advances in tire technology alone since the 1980s is revolutionary, not to mention ABS systems, EFI systems, cylinder head design, damper design, and more.
I'm not trying to disparage folks form NOT reading his 6 books - you should buy them and read them, they are still very helpful - but you have to realize that much of his race car building career was in the 1960s GT40 program and into the 1970s with formula cars. An S197 Mustang has little in common with those when it comes to finite details like "running without a rear swaybar".
Seriously, don't try to remove your swaybar at either end of your S197 Mustang. It will turn your big, heavy, stick axle unibody cars into a big hot mess. You are welcome to test this, but again, most of the "internet testing" I've seen regarding running no swaybars is so poorly done and inaccurate that these outlier data points can be chalked up to internet folklore.
There is some solid conventional wisdom surrounding swaybars - use them as a tuning tool and to help with transitional movement in the car, but not as a crutch for lack of spring rate. I see so many people discussing swaybars that still have OEM lowering springs on their cars. Those are too soft to even test with. Coilover springs are usually 300-500% stiffer than OEM springs, because that is what keeps are car from moving too far in roll, dive, or heave. If you don't even have proper monotube dampers, you aren't even in the ball park of good handling and you should stop trying to "overthink" shortcuts to proper suspension setup like removing swaybars.
Like the car above - you don't need to think about Watts Links or control arms, you need REAL SPRING RATE increases (and thus real dampers) before you do anything else to the suspension.
After you get quality coilovers on your S197 with proper spring rates (AT LEAST 4 TIMEs the OEM front rates) then you can experiment with swaybars effectively. Most times we see aftermarket front swaybars that are BOUND UP in the mounts. Out of the box virtually every aftermarket swaybar doesn't fit the chassis mount bushings, and it adds hundreds of pounds of roll resistance.
This is easy to check, and its happened to all of us. Disconnect both end links on a given swaybar and see if it rotates in the bushings with "pinkie finger effort". Most times I've seen an aftermarket bar it's so bound up that we can do pull ups on the swaybar... as in it takes 100-200 pounds of force to even move it. They NEVER fit well out of the box and the bushings and mounts usually need tweaks to get that "pinkie finger" low effort mounting. Not loose in the mounts, but FITTED PROPERLY in the mounts. It takes shimming the brackets, reaming the bushings to fit, or both.
Our first V8 BMW E36 above was a classic case of this. With an H&R front swaybar added, at the next autocross test event (shown above) the car pushed like mad (massive understeer) because it had too much front roll stiffness. It was getting up onto 2 wheels in transitions - too stiff! We took it back to the shop, put it on the lift, unhooked the endlinks, and I could hang my 200 pound body from the end of the swaybar. Wouldn't budge. We spaced the bracket down, ground the bushing a bit, got the bar to pivot freely, and then took it to another event... night and day difference. It was now neutral and the DEATH PUSH went away. No parts changed, not even swaybar settings, just fixed the swaybar pre-load in the mounts.
So look at your swaybars for this "bound up" condition, because it is ALL TOO COMMON. I've probably seen this 50 times in our shop with customer cars. That's something to worry about with swaybars, not their total deletion, good grief. And yes, some of the internet folks that swear their "no swaybar" setups are faster were likely victims of a "stuck" swaybar. Don't let that data confuse you....
/rant :yuno:
This post is chocked full of awesome.
The part about sway bars binding caught my eye (among other great points) because it's so important and easily overlooked.
So I checked mine and sure enough it was bound up to beat the band.
The bushing was so oversize compared to the clamp that even with the bolts loose it was unacceptably tight.
So I fabbed up this quickie solution:
CobraRed
Creator of Tools
LA
On my BMR 38mm with the endlinks detached the bar nearly falls down on its own with the bushings torqued on.
Not saying it's a precision fit, just doesn't seem to be an issue on mine.
Fabman
Pleasanton, Ca.
You could almost do pullups on mine. Way worth checking.
CobraRed
Creator of Tools
LA
Were you noticing front end push before, or do you notice less understeer now?
When installing, I was adjusting the endlink length and needed my sway to stay in place while I loaded the suspension with weight in the driver's seat, so I torqued the mounts on and the sway kept drooping down.
kcbrown
Then what physical mechanism is behind that? Why does it reduce power on exit understeer?
Fabman
Pleasanton, Ca.
Yes, everything about the car tells me it should be tail happy but it pushed at the track.
I knew something was fundamentally wrong so as I was going over things I checked the bar and low and behold it was super tight.
Fabman
Pleasanton, Ca.
So, where does one get a set of springs like "FR500s Ft 500 lbs./in Rr 300 lbs./in".
They are no longer listed in the ford racing/performance catalog.
Stiffest stock dia. springs I have found on the market so far are the H&R Race springs at only 325/285 pounds.
Tri-bar
The FR500s spring are Eibach's Front are 800-250-500. Rears are 800-250-300.
They are for a Coil over set up. Street, the best your going to get is the Maximum Springs
  • Front: 320-360 lb/in. The rate is progressive and approximate, ramping up from 320 lb/in at ride height to 360 lb/in at 2" of spring compression (about 1.9" of wheel travel).
  • Rear: 260-380 lb/in. The rate is progressive and approximate, ramping up from 260 lb/in at ride height to approximately 380 lb/in at 2" spring compression. Wheel travel is also 2" because the rear spring is on the axle.
Would run those with Bilstiens. Konis will bottom out.
DocB
NJ/PA
Incorrect.
The FR500S Rear Springs are 900-225-300.
Just sayin.
Fabman
Pleasanton, Ca.
"Maximum springs" as in "Maximum Motorsports"?
These? http://www.maximummotorsports.com/MM-Road-Track-springs-2005-14-Hardtop-Set-P1445.aspx
Norm Peterson
corner barstool sitter
RIP - You will be missed
Looks like them.
If it wasn't for the 2" lowering, you might be able to use yellows with them. Probably wouldn't have much headroom left on adjustment for the track though.
