How addictive is N2O?
00blkvert
Lillington, NC
I'm starting to plan to add nitrous to my car and was wondering if I would need a BAP on a 100 wey shot?
On a 15 I think you will be fine. But on my car full bolt ons and cams I was running out of bump with a 100 shot setup. I had to drop it down to a 75.
07TGGT
@user
Mansfield, TX
Alright thanks guys. I'll probably go with 42lb injectors or larger since I plan to do twins later on.
00blkvert
Lillington, NC
You wont need injectors. Most wet kits come with a fuel rail adapter so essentially the fuel that supplies the nitrous fuel line is coming out before your injectors.
07TGGT
@user
Mansfield, TX
Ah, good to know. I know nothing about nitrous and how it is setup.
I am looking at doing the Nitrous Outlet Single Nozzle kit.
I am confused as to which size I need to select for the Purge kit, nitrous and pressure gauges.
http://www.nitrousoutlet.com/efi-we...0-coyote-mustang-gt-single-nozzle-system.html
00blkvert
Lillington, NC
why not NX? I like nitrous outlet but you can get a plate kit for the same price as a nozzle from nitrous outlet. NX also has amazing customer service they helped me quite a few things. I had logs from when was getting my kit together from their chat room.
For purge you should only need a 4AN unless you upgraded to the 6AN line, the pressure gauges will be all the standard 1/8 sender thread like all general sending units unless you want an inline. You also dont need either of those pressure gauges if you plan to add your own auto meter or gauge of your choice.
I also have some odd ball shit left over you can have like a new bottle gauge if you wanted it and some small fittings.
07TGGT
@user
Mansfield, TX
Well, I was looking at NX first but my friend can get a deal from a guy he knows at NO. But if a plate kit is better than that's what I will go with. What are the advantages of plate over nozzle? Plate goes after the TB correct?
Alright, that makes sense. Thanks!
00blkvert
Lillington, NC
If you can get a good deal on NO then go for it. They also have a plate kit. I just liked my experience with NX. The plate has a better distribution of nitrous and the fuel into the intake, less likely to puddle and hits harder then a nozzle. Yes it also goes behind the TB.
pics06gtstang
SWFL n ft myers
Others may disagree but in IMO . NX is the best .
agreed NX rocks and they by far have the best nozzles on the market , they go by rwhp not flywheel hp on there jets , also as stated they are great with there customers and will help you no matter what !
jrgones
It may have been mentioned already but it's kind of like crack.
NUTCASE
If you motor is just bolt on you don't need to upgrade your fuel system.
Mine has a GT500 fuel system that I did just to be safe for future mods. But then later I decided once I get around 200 shot I am going the separate fuel system route anyway.
either way, if you need it, IMO GT500 fuel system is less of a bandaid and more of a solution when compared to a boost a pump on a stock GT pump.
