Fuel's Winter Project: Build It Before It Blows
05stroker
Never enough power guy!
Bullard Tx.
IIRC my rods have a bevel built into them (Manley H-beams, and I have a Kellogg 3.750 stroker crank) the bearings do not sit in the center they actually sit off to one side more than the other and of the course the side with the larger clearance faces the crank counter weight and the other side faces the other rod.
Sounds like you have the "Narrow" bearings like I have.
05stroker
Bullard Tx.
Bruce's looks like a beveled bearing. The others look like what I have. A "narrow" bearing. Both will work but depending on your rod, they may only have one side that contacts the counter weight. For instance, I have the Manley Billet I Beam rods. The set was originally made from a set of offset Chevy rods and have a set way the get installed. The newer ones are4.6/5.4 specific and can be flip flopped.
JoshK
Modder AKA Fuel
Nebraska
My bearings look just like swflastang05s. They are offset. They are also marked upper and lower. This is where I went wrong, I didn't pay attention to the offset of the bearings or the upper vs lower when installing them. This is a very embarrassing and expensive mistake. I can't believe I got in such a hurry doing such a task
JoshK
Modder AKA Fuel
Nebraska
Rod cap with upper bearing in it...
Rod cap with a lower bearing in it. Changes the offset to the other side.
Here are the upper and lower next to each other. You can see how the bearing clocking notch offset is different. With the right bearing in the correct place, the notches need to be on the same side (at least I had the right)
Welcome to engine building 1.01 Dammit
05stroker
Bullard Tx.
Those are my new bearings that I have never used though. I will check my old ones and the rod install of my old setup this weekend.
go302
Tits McGee
Oklahoma City
Just so I don't have to tear my shit back apart, this doesn't matter on stock stroke kelloggs, right?
Nope. The stock stroke cranks use a standard modular bearing. Stroker cranks use either Honda or small block chevy bearings.
All I can remember about mine are that they were Speed Pro and iirc they had a "CH" at the end of the part number. 7645 or something like that, lol.
Sealed Power Duroshield Competition Series Rod Bearings C87065CH
javascript:void(0);
$106.99
Qty
  • Free Shipping Over $99
  • Low Price Guarantee
  • Tech Advice
  • Easy Returns
Close Benefits of Buying Through Us
  • Free Shipping Over $99 Just place an order over $99, and we'll drop the shipping and handling charge. Learn More
  • Low Price Guarantee We're confident our prices are the lowest. We’ll beat any advertised price on an in-stock product. Learn More
  • Easy Returns You can return any new or unused item within 90 days of the date your item was shipped and we will refund the full purchase price. Learn More
  • Tech Advice Best Tech Advice and Customer Support, before and after your purchase! Learn More
Be the first to Review this product
Rod Bearings, Duroshield Competition Series, Standard Size, H-14, Chevy, 283, 327, Set of 8
Estimated Ship Date: Tomorrow Would you rather pick it up? Select Location
Email this page Facebook Twitter
Back to Results
Pretty sure this is what I used. I kept the box around so I'd know what I used but I can't find the box right now.
JoshK
Modder AKA Fuel
Nebraska
Anyone care to chime in on piston rings? I had moly rings in the engine the last go around and that definetly could have been a contributing factor to the engine failure. Trying to decide which to use.
Like we talked about the only ss rings that I've heard good feedback on were "Fire Rings". They will require a special hone and will require a motor teardown at 30k because of how hard they are on the cylinder walls.
eighty6gt
I don't think 12 psi is very hard on things. Maybe 25 you'd think about steel rings.
Good for selling parts.
JoshK
Modder AKA Fuel
Nebraska
So essentially the two sets of rings I listed above are the same rings? One set is Manley and the other ModMax is all?
I will have to search and see if I can find the rings you guys posted on summit since they seem a bit more affordable on there.
Edit. You guys are talking about the same Manley rings I have above. Looks like rings are another thing they like to up the price on for the big bore.
http://m.summitracing.com/search?keyword=Manley 46670st
