lskiller
- Joined
- Apr 11, 2015
- Posts
- 109
- Reaction score
- 0
Relevant details listed below.
I dyno'd my car with the KB3.2LC blower on it today. It made 810/710 at 6300RPM. This is spinning the blower at a max of 13,600 RPM. It's got way more power to give - this is my starting point.
Max boost logged was 20.6psi. The lines get squiggly after 5000rpm because the tires started to slip on the dyno drums. I imagine without that slipping, I would have seen slightly better numbers.
I have a 2.75 upper pulley that I've tested on the street but frankly it scared me lol. I'm driving it like this for a bit then I'll up the power.
Before this I had a 2.3L Whipple Gen I blower on this same engine. I spun it to about 17,500 rpm and saw 15.5psi and made 710/665 to the wheels (on Kroger E85) with that setup. All dyno numbers are corrected to STD Smoothing 3.
With more timing this will do 840/740 I think and when I go down a pulley size I expect close to 900/800 - that will spin the blower in the 15,000rpm range where it works much better. With an overdrive crank pulley I believe the blower is capable of close to 1000whp but I'm not going to try that - someone else can 8-]
Pulls like a freight train and I can't overstate how effortless this power was with this blower because I'm spinning it so relatively slow.
Basic Mods:
E80 from Kroger
Return style fuel system
Brenspeed B302 3v stock compression ~9.8:1
127-450 cams w/20* limiters
VMP3500 Maf
KB 3.2LC Blower
FRPP Stage III Heads
ARH 1 7/8 headers, 2.5" exhaust no cats
6.5" IW crank pulley
3.0" KB blower pulley
FB 4R70W trans
3.73 gears
DSS Carbon Fiber driveshaft
Tuned by me with SCT Advantage
IAT's started at about 96F and ended at about 107F during the runs. That's all I'm going to discuss about IATs. In my experience running this blower since July 2015 the IATs are a non-issue. ~thanks
Basic Mods:
E80 from Kroger
VMP3500 Maf
KB 3.2LC Blower
FB 4R70W trans
3.73 gears
