Fuel's Winter Project: Build It Before It Blows
JoshK
Modder AKA Fuel
Nebraska
Thanks Billy. Logs are showing some rich spikes in the Afr. Has us scratching or heads. Thinking have the injectors cleaned and flowed by ID? Not sure what else it may be.
slackinoff
East Texas
What about a momentary ignition issue? Im guessing you would notice a misfire, maybe not an incomplete burn. Just a passing thought I had.
R.M.
JoshK
Modder AKA Fuel
Nebraska
Misfire would show a lean spike. Wideband does not see unburnt fuel. That is why why you are on the two step the wideband shows lean
05stroker
Never enough power guy!
Bullard Tx.
When in doubt have them checked. Nothing worse then fueling issues! They never get better, only worse.
JoshK
Modder AKA Fuel
Nebraska
I wanted to go with the 94 series in the front and 92 in the rear. I think it looks cool and a little different from everything else.
weather man
Persistence Is A Bitch
MN
Well, if I squint my eyes, cock my head to the side and squat down a little, I can kinda sorta almost see what your trying for :goofy_batman:
If you like it, all good. :clap:
JoshK
Modder AKA Fuel
Nebraska
Small update on the car. I sent the ID1300 injectors out to LSXkiler Custom Calibrations to be cleaned and flow tested. He flowed them before and after cleaning. The injectors are now flowing within 3% and as you can see they picked up flow across the board. Waiting for them to show back up in the mail so I can get them installed and get some new logs done. Hopefully we will be ready for 30lbs soon
Before
After
