Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,808
- Reaction score
- 31
YesCan u tie the rear shock towers together on a vert ?
Don't laff at the BMR boxed sub frame connector's. Once welded in, they add a lot of rigidity.
I'm not discounting that they add rigidity. Only that they probably won't add anything measurable to a car with a tied together cage.
Take a cardboard shoebox with the lid off. Twist it with your hands. Easy right? Now put the lid on and tape it and try to twist it again. Not nearly as easy and you will probably crush the box before you get it to twist. That is what putting a cage in does.
Now take that open box again and tape 4 layers of shoe box material to the bottom and twist. It will still twist pretty easy. That is what the subframe connectors do.
Of course, all this stuff is extra weight. You could cut down on some of the weight by using 4130 Chromolly. DOM would be a bit heavier than CM for similar strength.
The cage will be CM.
). Norm's referenced article is a good read. Being a part of SAE was probably the most curriculum-related fun I had in college, and the guest speakers were always interesting.
