Let's Build A Killer Track Car!!!
Department Of Boost
Alpha Geek
thats pretty awesome, you should try and make it awd just for shits and giggles
Awd. Do it!
HaHaHa!!! NO!!:omfg:
The nice thing about the Vette-Cart is that there is very little engineering to do. Which is why I chose to go that way. All I'm really doing is building a cage/frame to tie the OEM drivetrain/suspension back together. The only tricky part is getting it sprung/damped correctly since it will be about half the weight of a "whole" C6. The Penske guys (they're 45min from me) said they could fire all the new weight numbers in the puter and come up with spring/damper rates. Then all I do is pull the parts off the shelf a la cart and build the dampers. That will be the most technical part of the project. And that's pretty easy.:clap:
