Car Aligned 3X still Drifts to Right
gus
The steering wheel is straight. When I take my hands off the wheel it shortly after begins driving to the right. It doesn't happen abruptly but it's not gradual either. Also I'm correcting the steering more than what's normally required during normal driving.
gus
Seems the same error either way...on gas or coasting.
Lucky_13
My vote would be for belts wonked out inside the tires, but you mentioned you swapped brakes as well. Any chance you have a sticking pad/caliper?
gus
Checked the brakes last night after seeing your post. Nothing appears to be dragging. All 4 wheels spin freely and I don't have one wheel with an excessive accumulation of black dust that usually goes along with dragging brakes.
ddd4114
Columbus, OH
Two very unlikely ideas...
1) Are your ride heights about even left to right? I can't imagine how you could screw up the geometry that much without visually noticing something is wrong, but it's easy to check.
2) Are your bushings in good shape? If they have slop in them, your alignment can change dynamically, and that could cause an intermittent pull. With only 21k miles, I really doubt they've seen that much abuse, but again, it's worth a quick inspection. Related to this, when you've taken in the car to be aligned, do you know if they adjusted anything after the first time?
TGR96
el blanco nino
Huntsville, AL
Running Conti DW
255/45/18 front
285/40/18 rear
The rear axle is shifted 1/4 inch to the drivers side. So an adjustable phb to pull it back 1/8 inch to center?
Unfortunately, I have nothing to offer that hasn't already been mentioned, but I will say that I previously had the Conti DWs in a square 285/40/18 set up on 18X10" wheels, and it tramlined like a sonuvagun!
Marble
Shasta county CA
I think eventually you'll have to take the car in and try different front tires. I just had this happen with mine and it was the tires.
gus
I started out with a car that never had an alignment issue. It was 10 years old so time to replace the tires. The tires had a perfect wear pattern and still had 7/32" While I was at it I wanted to run 18" wheels and swap to Brembos as the originals felt pretty weak for years after adding the E-force. Also wanted it a bit lower so I went with the entry level Roush springs.
Yes, the first time they adjusted the toe and each of the 3 visits they adjusted it again.
The ride height is level side to side.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
You do realize that particular types of tires and tread patterns can CAUSE tramlining, right? I had this exact issue with my previous autocross tires, and it would always go away when I put my street tires back on.
gus
Would the tramline happen in only one direction? In this case to the right.
Norm Peterson
corner barstool sitter
RIP - You will be missed
Do you know if these tires have asymmetric construction (not just the tread pattern)? If so, do you have any tires where the "OUTSIDE" labelling is on the inside? I would have expected any such reason for the drift to have followed your right vs left swap up front if it was a front tire issue. Have you swapped the rear tires side to side yet?
Do they all have at least roughly the same date? At least the tires on each individual axle to each other if not to the other axle's tires?
86GT351
Sunny South Florida
Having trouble getting my car aligned. Been back to the alignment shop 3 times. See alignment specs in pic.
The car is 06 GT with only 21K on it so I doubt any parts are worn. Big heavy E-force SC sitting on top has been on for years. Just changed to Brembos, 2010 GT 500 wheels, staggered 255/285 tires and Roush spring - mild ~3/4" drop front and rear. No alignment issues before this change. The alignment shop is a national chain but I only used them because they are close to home. So they are only going to put it "in-spec" not to a specific spec.
Based on these specs what would cause the car to drift right? Tested on a strip for road that 2 other cars go arrow straight for the full 2/10th mile. I've already tried rotating tires side to side.
Depending on the location of where you live the Caster Angle is a huge factor. Here in South Florida we like to see up to a Half Degree Higher on the Passenger Side. Theoretically that moves the Right Front Wheel slightly forward to keep the car tracking straight. Size of the tire and Air Pressure are contributing factors as well. I would also strongly suggest having the Toe Adjustment equaled out on both sides and centered as best as possible on the graph. I am a stickler for stuff like that because it rules out the alignment as a contributing factor.
Where are you located?
Beach Park, IL
I think you know this, but what I bolded above is backwards. A higher caster number will move the wheel further back.....very, very slightly. The car will pull to the side with the higher caster number or the shorter wheel base side.
86GT351
Sunny South Florida
By making the Passenger Front caster More Positive than the Drivers Side will help eliminate this concern
Norm Peterson
Depends on where you're making the caster adjustments.
As the caster adjustment of caster-camber plates, yes, the wheel would move rearward a tiny bit, guessing by maybe 25% of the amount you moved the plate. But for (outward) adjustments made at the rear bushings of the LCAs, more +caster moves the wheel forward, and by maybe 3 times the above amount for the same caster setting change.
Beach Park, IL
More positive = higher caster number = pulls to that side. Since you were talking about using caster to compensate for road crown, and since we drive on the right side of the road you would want to add caster (higher number, more positive, however you would like to label it) to the _drivers_ side of the car.
That said, I don't think caster is the problem in this case.
Am I the only one that thinks the negative camber in the right rear is the culprit? More negative camber on one side, just like more positive caster on one side, will cause a pull to that side. It didn't present as a problem until wider tires installed in the rear......just a theory.
Yep. I didn't even think you could adjust the control arm there without modification beyond the scope of the average alignment shop and assumed that adjustments were being made at the top if any adjustments were being made at all with regards to caster.
