Going from dragstrip/street to street/corners
Norm Peterson
corner barstool sitter
RIP - You will be missed
I upgraded the front brakes to the brembo kit (M-2300-S) recently. My expectation was a better experience than what I get from the stock rotors and Hawk HPS pads--coming down from speed has been white knuckle at times. My Focus ST brakes are stellar, and really bring the car down from speed. With the pads included in the Brembo kit on the Mustang, frankly, I just expected better. Without an exercise to actually measure the braking distance my observation is seat of the pants, but I am so far underwhelmed.
Do you know what pads were shipped with the kit?
Norm Peterson
I suspect they're still an OE street formulation of some sort, without nearly the 'bite' of even an entry-level track pad such as Carbotech XP8 / G-loc R8.
Good grief; do you read before you post? Norm was saying to use the highest hole on the brackets, meaning when the car is lowered, the arms would be parallel to the ground.
The highest holes on the brackets provide for a 2" drop. Only way the arms will be parallel to the ground is if 2" lowering springs also used. (This assumes the arms were parallel to the ground with oem springs, and even that will vary slightly, depending on tire diam used).
